mechycontrols
- Mar 5, 2004
- 3
Hello all,
First time posting here. I've got an assembly that I need to make a profiled cut on a flat surface (think of using a mill to cut a pattern no a surface). I need to include a radius at the bottom of this cut. Problem is, 'Swept Cut' is not available when you're in an assembly. Mind you, I'm not trying to add any material to the assembly, just trying to add a radius to the profile of the cut.
I did a search for 'Swept Cut' in assemblies, and found this closed thread: thread559-107328 (from a while back), but no real solution.
Any suggestions?
Thanks in advance!!!
Any suggestions?
