Sweep Blend
  • Thread starter Thread starter amd450
  • Start date Start date
A
amd450
Guest
I'm trying do a Sweep Blend, I created a datum curve with a model of a square and other like a circle and I did a arc with datum curve to do the trajectory, When I need select the section I dont got understand where went that I mistake. But I knew that my mistake happen when I need select the Section. What do I need do?
Andre Almeida
hello
lets make the feature from the start.
Insert > Protrusion > Swept Blend
SketchSec>NrmToOriginTraj>Done
Sketch Traj > pick the sketching plane > accept or not the direction and the orientation
Sketch the arc > OK > and the rotation of the z-axis > OK
Sketch the first section and click ok when its done.
Now sketch the next section on the other side of the arc (and enter the orientaion of the z-axis), sketch two centerlines (in purpose to use them to divide the circle into same number of entities as the first section).
Use the divide tool and divide the circle and Done.
Be careful to have the same start points
see the result
hope this helps
xcad
hello
see the result
hope this helps
xcad
