Swapping the models ?
  • Thread starter Thread starter saravanans_87
  • Start date Start date
S
saravanans_87
Guest
Hello all
Guys help needed !!
I have designed twodifferent parts with minimum difference between each other (Lets say a.prt & b.prt)
I have already created detail drawing for a.prt, then due to some contraints we have decided to go for b.prt.
Now is there a way to swap the model or ultimately i dont want to recreate the whole drawing as these drawings are having more than 100's of dimensions.
Any help.
Am using Creo 1.0.
Guys... Any thoughts ??
Are A and B together in a familytable?
No.. they are two individual parts.
We have a procedure we call "switcheroo." (Highly technical, I know.)
<B style="mso-bidi-font-weight: normal">
Family tables are the way to go.
Rebo... thanks ..
one thing i stuck is.. "
While the assembly is open, open part to be copied.<?:NAMESPACE PREFIX = O /><O:P></O:P>
Rename (under file pull-down) to the new name. Remember to fill out
Rename actually makes a copy of the part (or drawing.) <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Wrong. Save a Copy makes a copy...
When you have an assembly up in front of you, and you open a part contained in that assembly. Open your drawing. Select rename and save. Go to your part. Select rename. Save everything.
The assembly now has a new part, and the drawing exists.
Follow the rest of the procedure to switch out theexisting"B" part into the new one and its drawing.
dross - Just try it before you doubt me. I don't think it is planned functionality. I am using Creo/WF 5.
It will only make a copy if you save after making a change. It does this whether you rename or not. Simply renaming does not make a copy.
Ok - but I did say SAVE in the instructions.
No, this is what you said...
<Sigh>
In previous posts. ("The instructions.")
Never mind - I was just trying to help the guy. I'll shut up now.
Guys.. sorry for the late reply..
I hope the solution for my issue does not existed.
Thanks for ur time.
(mean while i recreated the drawing.. sh*t !!)
