Swapping models and keeping the same drawing
brudje
46
I am drawing a blank on this one guys...I have a fully dimensioned drawing, and I would like to keep the drawing, and swap out a similar model into the pre existing drawing. I have done this in the pst I am drawing a complete blank this morning.
What I normally do is copy the drawing with a new name. Then when you click open and browse to the copied drawing and select it, there is a button in the open dialog box called "References..." from there you can select a new reference to the other part/assembly.
Hope this makes sense!
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP1.1
have you tried swapping the models using SW Explorer?
What I have done...
[ol]
[li]Start with no files open[/li]
[li]Open the drawing.[/li]
[li]Open the associated model[/li]
[li]Do a Save as on the model, placing it in a temporary folder and giving it the same name as the new model.[/li]
[li]Save the drawing[/li]
[li]Close all files[/li]
[li]Open your new model[/li]
[li]Open your drawing. Answer all dialogs so as to allow drawing to accept currently open model.[/li]
[li]Save drawing and model to desired names and locations.[/li][/ol]
[bat]I could be the world's greatest underachiever, if I could just learn to apply myself.[bat]
-SolidWorks API VB programming help
