razzendahcuben
In SW Explorer I would like to know how to make the Description custom prop of the part as a label. (By label I mean the column headers in the right side windows: Name, Size, Type, Date Modified, etc.)
In Options-->Label tab you will see, at the bottom, "Choose 1 custom property to display". The box is grayed out. I found this in the help:
"The list is created from the properties created by the vault administrator on the Properties tab of the VaultAdmin tool.”
I'm not using PDM. All I want is the ability to create a label from the Description custom property of the part or assembly. Is this not possible? Thanks in advance.
