SW 2009 Lighting
jbknudsen
So what is up with lighting in 2009. I have just been upgraded from 07. I can not move/modify light position, color or intensity. I am not able to RC to bring up properties box either. Did i get a bad install???? Anyone else experiencing this issue.
Thanks,
Jay
Go to Tools\Options\Feature manager and turn your Lights, Cameras, and Scene to Show instead of automatic.
Then you will see the folders you used to see and will be able to control the lights etc...
Hope that helps answer your question.
Scott Baugh, CSWP [pc2]
"If it's not broke, Don't fix it!"
faq731-376
Eltron - Yes PW is loaded and added-in.
Sbaugh - This resolved the issue. now i have access to the folder and can manipulate items as needed.
Thanks to both of you for your quick comments, much appreciated.
-Jay
