SUSTAINED LIVE LOAD QUESTION 1
eyemeyar
SA
CAN SOMEBODY EXPLAIN TO ME THE REASON OF USING A TYPICAL 30% SUSTAINED LIVE LOAD USED IN COMPUTATION OF CONCRETE BEAM DEFLECTIONS?
THANKS. =)
Some component of the live load is generally sustained in nature and therefore would contribute to creep induced member deformation. 30% is an estimate of that component. You can modify the percentage if you're confident that an alternate value is more appropriate.
Thank you very much for the response. =)
