Susprog 3D help
ibelatti
Automotive
AR
A friend lent me its computer to play a little bit with Susprog 3D the software he uses to simulate suspension. He only uses it for McPhersons and trail arm suspension in touring cars.
I wanted to do a Formula Renault, the double A seems quite strightfoward to do. The main problem is the pull rod. After trying a little I sorted geometry out, but there is a problem.
The picture seems to be fine but the motion ratio that the program gives me is weird: -2.2
Can someone help me to sort out where can be the problem here?
The same happened with the double qwishbone front suspension of a touring car I wanted to study.
Can anyboy help, please?
You need great passion, because everything you do with great pleasure, you do well.
