XR250
- Jan 30, 2013
- 6,021
Got a 14 ft. x 16 ft. , 5 inch, plywood formed, exterior suspended slab. The slab is supported around the perimeter on CMU piers approximately 2.5 to 7 ft. O.C. The slab is 35 years old.
The underside of the slab is spalling due to corrosion jacking of the rebar –from decades of rain and deicing salt. The slab is sagging 1 inch in the center. Diagonal cracking exists in the corners of the slab near the cluster of support piers. The rebar appears to be spaced 5-6 inches on center and running in the short direction with about ¾” bottom cover. There is a patio below so the risk of concrete chunks falling on someone’s head is a possibility.
Rather than tear this whole slab out I was thinking of installing two I-beams underneath at third points to significantly cut the span of the concrete. My concern is that further spalling will occur and endanger someone’s life. Does anyone have any ideas on how to catch the debris or prevent further spalling? Chicken wire draped between the beams and perimeter? Frame a ceiling? What other risks exist here that I am overlooking?
