Suspended Slab Framing Economics
GreatDane2022
28
Before spending days researching, I was wondering if anyone had advice for the most economical solution for a second story residential concrete slab. Currently have concrete girders and beams but considering k-series joists and metal decking. 23 x 50 foot span with plenty of headroom.
Thanks!
It is going to depend on your local market conditions, labor force and the current price and availability of materials. Steel is super expensive right now - especially decking.
Although, I imagine for a house like this, cost may not be an issue.
Seems like I am always fighting costs. :) Labor (cost and availability) and simplicity (complicated designs are rarely executed well in residential) are my driving factors. Seems like by using k-series and decking, I reduce complexity and labor dramatically associated with forming beams/deck and shoring. Materials...you may have answered my question.
Indoors? Outdoors? Transfer slab or uniform load?
XR250 is absolutely right about the economics being region specific. That said, at 23' span you should be able to make a uniformly loaded residential flat plate slab work at 8"-10" thick. You'd then be down to dirt simple formwork and concrete but no steel trade / order.
Depending on how badly you want that "institutional feel" maybe even wood floor trusses and a topped OSB/plywood deck.
Thank you XR250 and KootK. Market is crazy where I am so you both made me think of alternate points which is always good.
KootK - I am sharpening my pencil to consider your ideas. I ran flat plate a while back but have slept since then. Never considered truss/plywood because I assumed it would be crazy money with lumber prices as high as they are but can't hurt to know instead of assuming.
Thanks again!
