I'm new to these forums and I had a quick question. I'm designing a suspended slab for a client and they want no visible beams on the exterior. two sides of the slab will connect with the house and the other two sides will be free. the two free sides will be held up with two HSS 4x4x1/4 columns. see the attached image. I designed this in RAM Elements and it just gives a required steel area to combat the forces. I can not find a design guide with this type of slab anywhere and was wondering if anyone could help. basically this will be a flat plate slab. I need help with the shear forces that will act on the columns (I also have a 16"x16" steel plate on top of the HSS to spread out the shear forces and act as a 16x16 column. Any help would be appreciated.
