usaedy
- Feb 17, 2005
- 9
Hello to all!
I just wanted to start up a conversation about benchmark adjustments. Does anyone have any experience with these at all?
I am looking at constructing a final, approved set of plans where the site was found to be extremely heavy. To achieve a balance the site design grades would have to be raised 9".
I would typically take the approved plans to our surveyor who performs our stakeout and contract him to redesign the site grading according to our houseline needs and give him the recommendation to raise the grades. We have been very succesful with this in the past. It works very well because we can send the redesigned grading plan to the excavator who will make the adjusments to his scheudule and the total dirt moved in the contract.
In this instance, I am going to use a benchmark adjustment. What this means is that instead of going through with the redesign by the surveyor, I have asked the surveyor to lower the benchmark by 9". This serves to make all the stakout higher by making the existing grade lower. Of course we got approval to do this by the township engineer...
In this instance though, I am running into a problem. The excavator is using GPS to grade the site. The existing topo in the cad file is based on the unadjusted benchmark. The will need to have the proper surface in order to make the correct cuts and fills. With the benchmark adjustment in place, we can't agree on how to get the site balanced correctly. I have to get the excavator to trust that the benchmark adjustment is going to create a balanced site and then get him to perform the work to the adjusted BM elevation.
Has anyone run into problems with benchmark adjustments in the past? What are your experiences?
