Autocast,
What version of SurfCAM do you have?
I thought the last version I used, a couple of years ago, started to have built in support...?
(I think that was SurfCAM 2000 or 2001)
I could be mistaking though, it has been several years since I last Used It...
Or is it that you can import SolidWorks models, but not export them...
Rocko,
The original intent of SolidWorks was to be a 100% Solid Modeler, where you are always working with solids...
If you wanted to use surfaces, there were other programs (like AutoCAD) that were more geared towards that area...
As SolidWorks grew and started gaining more ex-AutoCAD (and other CADs) users, they began to get more and more request and demands for feature that were in the other CAD packages, this is where supply and demand kicks in, next thing you know SolidWorks is released with a hand full of NON-Solid tools (such as surfaces...)
And the reason for parts NOT having the ability for Multi-Body was that, in reality, if a part has 2 parts, it is 2 parts... if you put 2 parts together, it is called an assembly (or sub-assembly), which is exactly what Solid Works had the abilility to create and support(until SW2003) because this goes along with the Solid Modeling Theory...
But as more and more people moved from their legacy CAD packages to Solid works, just like any other successful company, you have to offer support for the features of the previous CAD packages of other companies...
I agree that SolidWorks does not have as powerful Surface capabilities as other Packages... but if it was designed for Surfaces, it would be called SurfaceWorks and not SolidWorks...
And since SurfCam deals more with surfaces, it is called Surf(ace)CAM and not SolidCAM...
All,
In my opinion, SurfCAM is about where AutoCAD is in the industry...
It is not ready to die... But there are better options, depending on what you are working with...
Basically, SurfCAM is good for 2D Based CAD programs (with 3D capabilities) such as AutoCAD...
But if you Use true 3D based programs, such as SolidWorks, SolidEdge, Inventor... You would be better off with a package DESIGNED FOR 3D based CAD packages, such as...
ESPRIT:
-Or-
GibbsCAM:
I no longer do NC programming, myself, but our programmers here use ESPRIT w/ SolidWorks, And love it...
It might be worth checking into...
Thanks,
--Josh--
