rb1957
Aerospace
- Apr 15, 2005
- 16,002
have they deleted the option to specify the numbers of elements on a side ?
i meshed a bunch of surfaces at the same time (all with the same default size). usually it'll copy the meshing at an edge, but sometimes it doesn't (probably because the surface definition used different points, though i thought i was very careful). so i was left with one edge where i had 7 elements on one side and 6 on the other. no problem i thought, i'll change the meshing to be 6x4 elements (to match the adjacenet surfaces). but i couldn't find that option, so i just editted the mesh and added a triangle.
Quando Omni Flunkus Moritati
