Relatively new working with GD&T and on this forum.
ASME Y14.5-2009
Does the total runout (as a lonely requirement) shown control the surface location?
Again, the surface LOCATION, not the axis location (coaxiality).
Or the surface location is controlled by the combination between the total runout and size? (not the total runout by itself as a stand-alone callout/ requirement) ?
As we know, runout does not separate form and location deviations, so the amount each of these deviations contribute to the runout deviation will not be known. The verification of a runout tolerance reports the cumulative effects of form and axis offset. But the question is about the surface location.
Y14.5-2009 states:
9.4.2.1 Applied to Surfaces Around an Axis. Where
applied to surfaces, constructed around a datum axis,
total runout may be used to control cumulative variations
such as circularity, straightness, coaxiality, angularity,
taper, and profile of a surface.
ASME Y14.5-2009
Y14.5-2009 states:
