C
cloughna
Guest
I've got two 4-sided boundary blends with a common edge. The constraint at
that edge is 'curvature' and everything solves nicely.
However, upon doing a surface knot analysis there is a problem: a surface
knot 'discontinuity' between the two surfaces. This shows up slightly when I
run a mean curvature analysis and I'd like to clean it up.
I was playing around with the surface edit feature in isdx tonight and
couldn't get quite right (although I feel as though I'm on the right path).
Any thoughts?
Any thoughts?
