ChipFuller
- Apr 18, 2003
- 47
I've got a project that requires us to do full penetration welds and surface inspect welds on the inside of stainless steel pipes. The material going through the pipe is an explosive. I figured that dye penetrant inpsecting is out because a person can see back inside of the pipe. Will X-ray inpsection detect surface flaws? And is it as good as dye penetrant inspection?
