Surface Gap from igs file
jessssica
Aerospace
ES
Hi everyone
I´m new in the forum I working with catia v5 r16 and opened an igs file and cannot join the surfaces
I tried to join it using Join icon but there are gaps more than 0.001mm and apeear me connexity problem
I need to have surfaces closed so could you please tell me how to solve this? what is the best way to work?what should I do this?
Thank you so much and I hope to have news from you soon
Enzo
try healing or change your tolerance to .01 and see what happens
Just in case you don't know where to find the import tolerance it is
Tools->Options->General->Compatability->IGES tab->Continuity Optimization of Curves and Surfaces->Advanced Optimisation->Parameters
The docs for these settings are on this page in your documentation
DOCUMENTATION PATH/English/online/bascuitf_C2/bascuitf0400.htm
Hi 1oldcaduser and Peterguy
Thank you so much both for your help and please tell you that I imported the igs file from ProE to CATIA v5 r16 and I´m trying to close the surface with mergin distance 0.001 to do a close surface with solid and let me ask how should I do this? I triying to close with healing tool but whe I use the join the are connexity error
to finish what does mean the green boundary when I use join and healing?
Thank you everyone I hope to have help please from you
see you in advance
Enzo
