Surface Finish No. 5
FH
170
Hi Guys,
I am looking for the definition of "Sutface Finish No. 5".
What standard is it based on?
and
How can I measure or verify it on a piece?
Thanks in advance,
I am assuming that this refers to SSPC-SP 5, which is a 'white metal blasting cleaning' surface preparation. SSPC stood for the "Steel Structures Painting Council", but was recently renamed the "Society for Protective Coatings". Their web site is
Stainless steel is rated on a number scale, which is usually a very subjective one, but as far as I know there is no "5" in the scale (I don't know why). If the spec is really picky, you can use a profilometer to measure the finish.
Is it stainless steel?
Don
Kansas City
In tool & die terms, a #5 finish usually meant a 5 micron finish (shop jargon). Visually on a punch face, it usually meant you lapped it to a near mirror shine, finishing up with #3-#6 diamond paste (yellow & orange respectively) depending upon your polishing technique.
I doubt if it's a micron or micro-inch finish. This kind of finish would be called out in the familiar "check mark" symbol, not as "no. 5 finish".
5 is not a preferred number in either system. Micro-inch callouts would be numbers like
4, 8, 16, 32, 63, 125, 250, etc.
and the preferred metric ones would be
0.10, 0.20, 0.40, 0.80, 1.60, 3.2, 6.3, etc.
A finish of 5 microns would be pretty coarse, on the order of 200 u-in and equivalent to a sawn or drilled finish.
Don
Kansas City
Gotta learn not to throw the "n" in there...you're right on the micro-inch. A #5 was the equivalent of a 5 u-in. Thanks for the catch.
#5 would not be common, but for some reason a certain shop in NC (old customer) preferred to use odd numbers, specifically 1, 3, & 5.
This could also be an SPE callout, if it is referring to a mold finish.
"Surface finish designation like #4, #8 etc refer to the grit of the polishing media used to create the finish (for example #4 uses a grit of between 120 and 150 to obtain the surface polish)."
Thanks to GRoStruc in thread330-190474 and his link to the Specialty Steel Industry of North America.
