The best is anodize without sealing. However the stycast application has to be as soon as possible after the anodize before the anodized surface absorbs humidity from the air. This is a common procedure for painting of aluminum alloys.
However, if the plate is already anodized and sealed the surface should be cleaned using a solvent recommended by the stycast manufacturer (see their catalog and technical info.
