I'm designing a light duty gearbox based loosely on an existing unit purchased from an outside vendor. It exclusively uses PM spur and bevel gears, made of a relatively strong alloy (FL-4405 or 5305 with heat treating.)I'm using MITCalc, as well as Dudley's Gear Handbook, in the gear design process.
I am confused, however, about surface stress and durability in the gears. According to the software calculations, HP throughputs commonly encountered in normal operation are enough to create massive surface pressures (in excess of 250 KSI in the differential pinion). MITCalc predicts a surface durability saftey factor of less than 1 for these conditions, despite that this transmission is intended for a sub-500 hour life. According to my MPIF handbook, 250KSI is the extreme limit of rolling fatigue even for the highest rated alloys.
On one hand, I know these gears are sufficient based on thousands of purchased units that have operated well beyond their predicted life. On the other hand, I cannot justify the current gearing dimensions with any calculations. Bending strength is never an issue.
Any thoughts on how to treat these questionable surface pressure predictions?
