I'm having a bit of difficulty creating surface constraints in ABAQUS. Currently, I have an imported mesh of a knee generated from ScanIP. I set up contacts in ScanIP, and so when I import it, ABAQUS recognizes the contact nodes from the original mesh. However, I'll be putting a load at the top of the knee, and my parts will slide past these predefined contact points. Thus, I want to extend my contact zones to cover entire surfaces (i.e. medial femoral cartilage --> medial meniscus).
I tried to do this by going to tools -> surface -> manager -> edit
I edited each contact area by selecting the entire surface of my parts using the "select by angle" mechanism. However, when I run the model, it's pretty evident I've made a mistake because my femur is not recognizing the contact underneath it and is sliding all the way through my tibia. I'm getting warning messages saying that node constraints are being removed.
If anyone has any advice or insight into this, I would be much appreciative!
Lance
Lance
