The situation I'm in is that I am using a Motor I/O Card to control two different motors. The card has two outputs to control the motors. The card is being used in conjunction with a PC104 card, which will control the motion of the motors through the Motor I/O Card.
The problem I have is that the Motor I/O card can only output a maximum of 3A and an absolute maximum of 6A for very short transients --- however each motor draws upto 11A initially before settling to steady-state of 1-1.5A.
So what I want to do is find a way to supress that initial current needed by the motor.
It has been suggested to me that the use of capcitors across the battery would be an effective solution and the use of Power Mosfets was also suggested.
Does anyone have any comments on these or any other solutions to this problem.
Thanks in advance,
joe.
Thanks in advance,
joe.
