electricpete
Is there a way to supress display of cells that are the same as cell directly above.
I can do it on a single column with conditional formatting by selecting column range for example B2:10 and settin format to zero if condition1 is cell = B1. Apparently it treats B1 as relative cell reference compared to first cell on the range. If B4 is same as B5, then B5 is supressed (that's what I want).
Now the problem, I would like to do it over a block of data several columns wide. Conditional formatting won't let me do it. If I select B2:F10, and try to test for equal to B1:F1, it gives me error message
