Suppressing component arrays in NX6 assemblies
jaydu
IN
I have created a ball bearing assembly with 6 balls. I want to control the number of retainers in an array between the balls with an expression as " NUMBER_RETAINER= NUMBER_BALLS/2"
I have suppressed the parent of the circular array with an expression.
Now, Do i also need to suppress all the array menbers using the same expression?
If I change the number of balls, the array members are still displaying and only the parent is suppressed.
How do I fix this problem?
Thanks in advance
What version are you using?
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
I think I have an answer for you. In the component array you just need a boolean operation to control the number of instances. It could look like this:
if(Supress_Balls=1)(Number_Balls)else(1)
This way, if the master is suppressed, it changes the array count to 1 and gets rid of all of the other balls. I hope this helps. Good luck.
