fluctuations99
Chemical
Theoretically I am needing to get water to the top of a ~200ft structure while also supplying two units along the way. The top of the structure will just need to be able to supply water when needed for general use and occasionally hooking up a pressure washer (40psi, 3gpm typical?). The water at the top will only need to be used every few weeks. However, I also need to supply a 10gpm unit 70ft up the structure and two more 10gpm units 120ft up the structure. These units will need water flow at all times.
If I have single pump that can meet the whole systems demands, will it deadhead the pump since the top of the structure will not have flow? Should I use a VFD for when we need water at the top and just meet the demands of the units for the majority of the time? I also am not sure if break tanks and boosters should be used in this scenario. Just wanting to know how some of you would approach this problem.
