plantprowler
Chemical
- Aug 10, 2013
- 136
In Ludwig's Handbook I found a correlation for air agitation intensity using gas sparging that is based on "superficial gas velocity". See image below; Thumb Rule #5.
I am confused about the correct area basis to use when calculating a superficial gas velocity in a tank: Would this be based on the tank's entire cross section? i.e. I multiply velocity by C/S Area of tank to get gas flow rate?
![URL]](https://res.cloudinary.com/engtips/image/fetch/w_800,c_lfill,q_auto,f_auto,g_faces:center/[URL unfurl="true"]http://i.imgur.com/kAdg9Z1.png[/URL])
