Hi everyone,
Quick question, I work in gas compression services, mainly gas lift with pretty high discharge pressures (up to 3500 psig, three-stage reciprocating compressors), I came across with a analysis of a gas composition we sent for survey a few years ago and noticed it reaches supercritical conditions within compression. Question is, since this supercritical conditions are reached inside the very cylinder chamber, is it safe to operate that way?, meaning theory says the gas density will be near to liquid-like whereas viscosity will be gas-like.
It is worth noting we´ve operated that way for many years, without any gas treatment prior compression, so the answer can be it is actually safe, but, since we know liquids is the worst enemy of a recip what is the key for backing the safe operation at those conditions?
Please note below the phase envelope, indicating the operating condition (light blue dot) well positioned in the supercritical region.
