Enginead,
What is so very useful in the experience that you shared here is that you mention the compensation from the two MAP sensors onto the ETC and torque model.
The ECU takes into account what the charger/bypassvalve is doing by sensing the pressure before and after the charger.
How it compensates engine parameters will be load dependent at first because these absolute pressures are load dependent.
It is to note that in principle the ETC hardware is quite similar to the electromechanical bypass valve as used on the MB engine.
The valve control that I described in my previous post and which is used now is load dependant too, albeit in a more crude way because the cable actuated throttle plays a role in it. Anyway it will be more load dependant than my first approach.
Winter was long and the opportunities to test on dry roads were very rare.
The first -short- tests with this system look promising.
The attached picture shows the path to a certain improvement.
X is MAP in bar (scaled to 0 = atmospheric), Y is TPS in volts.
On the second graph, compared to the first one, the gain of the MAF amplifier has been increased what makes boost build up over a wider range of TPS.
Then for the third graph, the offset between the MAF and TPS signals is reduced.
Boost buildup is more "the extension" of the manifold vacuum.
Obviously, that was the setting yielding smoothest throttle response.
What has to be refined? The slope of the positive pressure as function of the throttle position is still steeper than the vacuum as function of throttle. I think drivability might benefit from
stretching even more this part of the action.
As to your question what I am trying to do I can answer you the following.
This has nothing to do with my job.
I'm working full time professionally, who knows even knowledgeably, doing something completely different. Don't ask me why. Partially it was destiny...
I have been charmed by the technique that I found when I bought this car (Nissan S13 with CA18DET engine), meanwhile ten years ago.
That was quite a difference compared to my old twin-DCOE commuter.
Since then I have walked different ways and meanwhile it became a project car.
After being tired of playing with turbo's I mounted this charger that I had available.
The challenge now is to optimise its control.
A first ECU remapping has been done last year and once I will have satisfactory results with this bypass, I plan to increase the boost.
What will be next? Who knows, I have other hobbies too, and a lack of space and time.
You will understand that given the situation, the potential of significant compromise is virtually inexhaustible
