I would like to revisit a question I asked a long time ago. I have still not been able to resolve the problem. The original post was this:
thread407-188371
I will briefly repeat my summary. We have two identical Sundyne pumps, model LMV 341. One of them has had three failures where the inducer came loose and water leaked under the sleeve directly into the gearbox. We also have a problem that may be totally unrelated. Both pumps are experiencing rapid cavitation damage despite the fact that they are running at exactly BEP and have an NPSH margin of more than 80 feet. Since my last reply to my original post, the spare pump has failed. That pump had even more extreme cavitation damage in the impeller eye than we had seen in the main pump. We have not had any more problems with loose inducers or water leakage into the gearbox.
I am now focused more on the cause of the cavitation damage. Two points have occurred to me that I would like to explore. First, anyone familiar with Sundyne pump knows that most models have the suction and discharge flange in line with one another and centered on the impeller center line. There are only two models that deviate from this pattern. In the direct drive (no gearbox) models, Model LMV-806 has the suction and discharge flanges offset to one side of the centerline of the impeller. Since they are direct drive, they are limited in speed to 3600 rpm (60 Hz) or 3000 rpm (50 Hz). But the model of our new pumps has this same feature. A colleague suggested that pre-rotation into the inducer could be the cause of the cavitation. When I began to analyze the installation, I noted the flange orientation and a piping issue. The flanges on this case are oriented such that the incoming flow would tend to pre-rotate in a counter-clockwise direction because of the offset of the flanges. The impeller rotates counter-clockwise. This is the same issue as with the LMV-806, but in the LMV-341, there is the possibility of shaft speeds as high as 22,000 rpm. Our pumps run at about 19,000 rpm.
The second issue was piping arrangement. Our suction line has a horizontal elbow about 60 inches before the suction flange. But for a 4 inch line, this is allowed by our specifications. It may be coincidence, but this horizontal bend is also oriented such that it would tend to pre-rotate the fluid in a counter-clockwise direction.
I am beginning to believe that pre-rotation could be the central issue in the ongoing cavitation problem. I also wonder if this could have played some role in the problem with inducers coming loose.
I am interested in your opinions or experiences that may be relevant to pre-rotation into an axial flow inducer. Could this negate the affect of the inducer? Could the pre-rotation result in cavitation even with an extremely high NPSH margin? Could a piping bend more than 10 pipe diameters before the suction be contributing to a pre-rotation problem? Any experiences, opinions or suggestions will be greatly appreciated.
Johnny Pellin
thread407-188371
Johnny Pellin
