larrycarola
Computer
We moved in to our new home 20 months ago. We have a sump pump in our basement in an 18” x 24” polyethylene pit. The water level rises about 8” and the pump runs for 6-8 seconds just about every hour. My calculations indicate the water is flowing in at about 8 gallons an hour. This seems excessive to me.
I also noticed that no water ever comes in through the 4” inch inlet pipe.
In an attempt to find the problem I turned the pump off and manually drained the pit. Keeping the pump off I then let the pit fill up naturally to see if it would overflow. Fortunately it did not overflow. The water level rose to about 16” and stopped just below the inlet pipe.
I manually drained the tank again, and saw that water appeared to be coming in from the very bottom or floor of the pit under the raised pump.
I assume that water should only enter the pit through the inlet pipe. If this correct, this leads me to believe there must be a crack or hole in the bottom of the pit.
• Can the pit be patched or must it be replaced?
• And would this solve the influx of water or is it likely to seek a new level?
• Is it likely that the pit was defective at installation
• Given that it was not, is hydrostatic pressure a likely suspect and would it just crack a new pit?
I appreciate any insight anyone can offer!
