Sum Corresponding values
MEM1
Hello All,
I have a list of names in one column and several values in a second column. I want to lookup all occurances of each name in column 1 and sum the corresponding values in column 2. Can someone please help me with this?
Example
Scott 1
Jon 2
Scott 3
Lookup "Scott" and return 3+1 = 4
Any help is greatly appreciated.
Have you tried SUMIF? It seems to be tailor-made for your application.
TTFN
You could also look at Pivot tables if you want an "automaic" sum of all your "labels".
In your example a pivot table would produc a result table looking something like this (you have a add a label in the row above name/values:
Sum of value Name
Jon Scott Grand Total
Total 2 4 6
or the other way around:
Sum of value
Name Total
Jon 2
Scott 4
Grand Total 6
Its very easy to costumise and ideal for making summaries etc.
Best regards
Morten
Dear MEM1,
There is a simple solution:
1- Use AutoFilter to filter the data on each name
2- Use the SUBTOTAL function to sum the corresponding data in second column (the AutoSum button automatically uses the SUBTOTAL function if used for AutoFiltered tables.
Farzad
Going with IRstuff's suggestion of using SUMIF, if your entries are in cells A1:A3, and B1:B3 then use
=SUMIF(A1:A3,"Scott",B1:B3)
to get 4 for data in your post.
Yogi Anand, D.Eng, P.E.
ANAND Enterprises
Computers-Education-Engg-Networking
yogia@hotmail.com
anand@oakland.edu
