sydneyjongleur
Materials
- Jul 22, 2011
- 39
I work in the manufacture of aerospace components and I was looking for some advice on stable materials for fixturing these components.
The fixtures can range from 200mm to 1200mm in diameter and between 30mm and 60mm thick.
We currently manufacture from mild steel but are looking to get away from this due to the material movement and wear. We have recenlty tried EN8 with better results and have also considered the cast iron route(although this has an expense attached).
Cost will obviously be a factor in this although quality of the workholding is more important in order to produce these expensive components.
