Suitable material for Alkali service
Steph100
Petroleum
GB
Customer has no idea which material to use, product is triple offset butterfly valve - example of alkali service was given as caustic soda (ph 13).
Looking through PMAs only an Cy40 material mentions alkali service so need some guidance please!
Thank You!
Check to see if the caustic soda is a mixture of NaOH or sodium hydroxide and water. Whatever the answer, google the fluid such as NaOH, water & material.
Are you sure that the pH is only 13? This corresponds to a 0.4 wt% NaOH solution. A pH of 14 corresponds to 7.4 wt% NaOH, and 50% NaOH is the usual solution as commercially shipped. For practically everything you need to know about caustic soda, including storage & handling, see the
OxyChem Caustic Soda Handbook
