I am interested in hearing how some of you might approach a definition using GD&T of a ball screw assembly containing machined ends. I am interested in making sure the ball nut will always be able to be positioned/aligned within the center of rotation of the screw and machined ends/journals by a certain amount, for assembly consideration at the next level up. The ball nut and screw contain some radial lash and this can be utilized to satisfy the centering condition. I would be interested in making sure this condition applies over the whole range of travel of the nut on the threaded portion of the screw. I can clarify the application if needed, but can't post any pictures/drawings.
Pete
Pete
