Here is the second question. For the project I will require some non volatile memory for temporary storage while the unit is unpowered. I designed the board using a Dallas-Maxim part, but it is only a byte wide part. Since just about every device on the system is 16 bits wide and the processor isn't byte addressable, this becomes a real inconvenience. The problem is that in x16 sizing, or with two devices in parallel, Dallas chips get very expensive.
The present device on the board is only 32K x8, but it does have a real time clock which is a plus. If I use a different device, I will need to use a clock chip too, which isn't too big of a deal.
I was wondering if anybody has any suggestions or recommendations for NV ram that they have had a good experience with?
