vesselguy
Petroleum
- Feb 25, 2002
- 386
I'm having some trouble finding a workable solution for my s&t thermal run in HTRI and would like to get some suggestion for a configuration. I have a water-water exchanger with one stream having only a mass flow rate of 1/4 of the other. I am using a BEM and put the high flow steam in the shell and split the flow in parallel to reduce the shell side stream velocity and to minimize the vibration. the problem now is the tube side velocity is extremly low. I've tried a single shell BHM and got some improment but still getting a tube velocity of 0.2m/s. Too low. Can I please get some suggestions? Thanks.
