In our project we have a concrete fire tank which is lower in level than the fire pump room by 590 mm, taking in consideration the level at which the suction pipe will be fixed in the tank that means it will exceed 1000 mm from suction to bottom of tank.
Is this acceptable or it will affect the pump readings during the handing over to the local authority? (in addition to cavitation)
The second part of my question is regarding the drain of fire tank, in our case if we provide drain for tank inside pump room that means a part of tank volume which is below the pump room will not be drained, so what is your advice please?
*pump used is horizontal split case*
