Hello Group
I have a query regarding suction lift pumping
The pump is a Double Suction Centrifugal with 2x Mech seals.
The Pump is primed with a system which fills the pump casing with water ready for pump start up.
So the pump is full and it beings to lift the water from the reservoir.
Where does the pump / fluid get its NPSH from?
Being a pump novice, I always understood you have to have a head? Does the priming system keep a pressure at the suction?
My next query is regaring the 'vacuum'
The pump maker says the stuffing boxes / seals will see vacuum on start up.
Does this mean all the fluid placed there by the priming system will go move out and let the seal run dry?
My thoughts were if there was a vac the water would try and fill the space?
This pump always seem to have a dry running seal issue.
The air is/should be vented when priming but it seems like
some is always present.
All joints are thought to be tight (after initial problems)
Could air / gas be evolving somehow??
Any advice appreciate
Any URLs or pdfs available on Suction Lift pumping and the like would be appreciated also
Milkboy
Milkboy
