I made a big Global model, and i want to focus on a small part of that Global mode by using Submodel technique.
I notice that all sets generated in the Global model are not propagated to the Submodel when these sets are created in the Assembly module, and i got a generation failed message in the Assembly module, and i see a red cross beside all these sets in the Assembly module. However, i do not get this message when all these sets are created in the Part module in the Global model.
So, my first question is: to use the submodel technique, all the sets should be created in the part module? please correct me if i am wrong.
My second question is, when i run the Submodel which covers a small region of the Global model, i get warning messages about "unknown set-1, unknown set-2, etc...", all these sets are defined with initial conditions in the Global model.
So what is wrong with the Submodel? Please Advice me.
Thank you in advance.
