I've designed & manufactured systems in Ireland using submerged filter media, and it does have it's advantages. The microbial mass on the surface of the media can be very large, especially with some of the better made media, which tends to come in large blocks rather than discrete pieces. Also, although the depth is not much on the media, it does significantly help against shocks to the system generally, such as the housewife throwing gallons of bleach down the drain at spring cleaning time! The layers are a good protection against such shocks, which can put a sytem back to no microbes at all. Media that we used had area ranges from 95 to 150 square metres per cubic metre.
