Subgrade Modulus Unit Conversion
SteelPE
2,759
I have a pretty basic question regarding foundation spring modeling in regards to a slab on grade. I have a subgrade modulus from my Geotech of 200 pci for the soil under my slab. I am trying to model different loadings on the slab using my FEM software. The software allows me to enter the subgrade modulus but it is requesting the units of kip/ft2/ft.
I modeled a 40’x40’ section of slab using 1’-0” square quadrilateral plates (I don’t really want to refine the mat mesh much from here). So it seems like the proper value for the software would be 200pci x (12 in/ft x 12in/ft x 12 in/ft) /1000 = 345.6
This number seems really high to me. Is this the proper unit conversion to get 200 pci into a unit of kip/ft2/ft?
200pci is toward the top of the range, but still reasonable for slab design.
Mat footings are a little bit different animal and often have a sub grade modulus which is just a fraction of that used for pavement design. Sometimes the Geotech provides this but often you have to request this value.
JLNJ,
I realize that this isn't the best approach to design the slab and that there are a few holes in my approach. At this point I am just wanting to make sure I am doing the conversion properly. Once I know that then I can reduce the sub grade modulus to see the effects on the slab.
kip/ft^3 ?
MathCAD thinks that you know your 8th grade unit manipulations. I didn't trust myself to do it.
you're correct... with the order of operations... still k/ft^3
Dik, it's written as /ft2/ft (etc.) to clarify that the parameter is not a density, it is a pressure which increases (linearly) with depth. a pressure per unit deflection, as IDS states below.
Works out the same, but an important nuance for engineers not familiar with the concept of subgrade modulus
just call me Lo.
Lomarandil, it's also the density of a fluid that would exert the same pressure on the base if submerged to the same depth
A pressure increasing linearly with depth would have the same units, but a subgrade modulus is given at a specified depth.
It is a reaction stiffness, expressed as a pressure per unit deflection.
Doug Jenkins
Interactive Design Services
Apropos of nothing, the density of gold is 0.70 pci.
