Subassembly modification
gregfox
Bioengineer
Mar 15, 2007
29
Say I am building a box out of separate parts (not molded). I would have bottom, sides, and front and back. I would like to radius the sides of the finished box, but the parts files should remain non radiused. How is this done. Ideally too, I would like a subassembly of the fabricated box with out the radii, as it might be on a manufacturing shelf this way.
Do you mean radius the edges of the side plate where they meet the front and back plates?
Or do you mean bend the side plates into a curve?
[cheers]
Assuming the side plate is internal, then in this case the edge of the front and back plates would be radiused. For the cutlist/BOM, the front/back plate file would show a part with out the radius, as they would simply be pieces cut to be fabricated.
In top view, it would be a rectangle with radiuses on each corner. Depending on the size of the material the sidepieces may or may not be effected. Generally they would not though. If this were a molded box, the outer edges of the box would have radii running upward.
Thanks a bunch, I'll give it a try
