I have been approached by a survey team who suggest that I need to do a "...Sub-Slab Depressurization..." on my building. I have a 20,000 sq. ft. commercial structure with a 30ft high roof.
I have been surfing the web for some information regarding the need and cost of this procedure. I have determined that this is primarily reserved for the metering off of Radon Gases from residential properties.
I have a couple of questions:
1) Is it possible to perform Sub-Slab Depressurization on a building of this size?
2) Is it necessary to perform Sub-Slab Depressurization on a well-ventilated building of this size?
3) What would be the cost of this procedure, ($100's or $1,000,000's)?
Sources for supporting documentation would be appreciated.
Thank you in advance for any guidance you provide.
Respectfully,
Darrell
Respectfully,
Darrell
