Stuck in snow - with a Ford 4WD!?
Skogsgurra
SE
My Ford Kuga, a mini SUV, has served well for a couple of years. And it served well when I left home today. It served well when going back home, also.
But, there is a small hill and a right turn just before I can park before the front door. It had been snowing and weather was "wet", so quite slippery. No probs, I thought and turned the wheel to get through the gate, which - of course - was open.
I got stuck. Pressed pedal a little more. With four wheels, you don't get stuck in a situation like this. All that happened was the the front wheels digged little holes and there I was. Stuck. The back wheels hadn't turned at all.
My garage has closed. I have no idea what has happened. My guess is that the logic telling the AWD to activate doesn't work. Or something.. Probably some electronic thing hat I Primo: Don't trust and Secundo: Don't understand.
Does any one in Automotive know what is going on? And if there is an easy late Friday afternoon fix?
Gunnar Englund
Best Tip of the Week! aka known as BTW. Followed by "sorry, I forgot to tell you about the ice and dirt"
Gunnar Englund
Pat, I figured that was implied in my post;-).
Posting guidelines faq731-376 (probably not aimed specifically at you)
What is Engineering anyway: faq1088-1484
No, not this time. But zink (not tin) whiskers were considered in an investigation that I conducted several years ago where heavy arcing was initiated by "something". We later found out that it was trapped water inside a hollow insulator that started the whole thing. But whiskers were not ruled out until we found the faulty insulator and others that had the same problem.
Gunnar Englund
