My structure has the first natural frequency at approx.15 Hz. The structure is mounted on a foundation with stiffness approx. 30 Hz. The manufacturer of the foundation claims he can measure the 15 Hz. frequency at the foundation. I would assume that if you have the 15 Hz at the structure and the 30 Hz at the foundation, the separation should be enough to not see any significant accelerations at 15 Hz at the foundation. So where could the 15 Hz. come from? Do I need more separation between the structure and the foundation?
