loki3000
- Sep 29, 2009
- 652
hello,
can someone enlighten me on how to work in the strucure design workbench?
my final intent is to design a yacht cradle, used to hold the entire hull or deck of the yacht. similar to the one here:
but much more complex.
the profiles are more or less rectangular hollow with varying dimensions.
right now that's done with simple sketches and extrude
(not me yet, the ones before me; mostly due to the lack of training) but i'm trying to learn the SD workbench hoping that it would somewhat automate/ quicken the process.
i've tried sketching a simple frame (box, but without using the grid option, as i don't see it applicable in the final design), but i've learned that i have to publish the geometry. the problem is that there is no such option nor in the part design where i made the initial wireframe nor in the SD workbench. i will consult online help though for it.
so, for starters, how time consuming is this publishing, when done on a larger level (maybe 100-200 elements)?
can you provide any best practices that i should follow?
i have a good basic knowledge of catia (part, asm, dft, much of that inherited from other cad packages though), but not advanced features (publications - solidworks doesn't have them either for example).
training is not (yet) an option and frankly i also doubt that the local VAR is familiarized with the workbench so much that they could do more then read from the training script)
![[smile] [smile] [smile]](/data/assets/smilies/smile.gif)
