COEngineeer
- Sep 30, 2006
- 1,186
I have this residential house project where I have a non typical window. If you see the cross section, it goes from main level to top of 2nd floor then it cuves to the ridge beam. First I just drew it and put "Structural windor per manuf.". The city responded back that I need detail for it. So my question is, what type of X-section can I bend so I can use it as bent "king stud"? Can you bend rectangular tubing? Channels? The architect thinks the member should not be thicker than 5" wide(4 windows in a row). What do you think I should use? I guess once I design the structure I just put a note on the windows especially the one that curves on the top to make sure it can take the snow load.
