Structural integrity of a hanging tent platform 1
treeclimberr
8
I am planning on building a tent platform that will hang from four trees. My plan is a 10'x10' platform constructed with 2x8s with 15" center to center joist spacing. Flooring will be the lightest plywood I can find. Will this platform be structurally sound if hung by all four corners, especially if the strain is not 100% vertical, but more along the lines of 45 deg.? All the platform will hold is a mattress and myself with a simple A-frame covered in shrink which I don't anticipate will add to the weight significantly. I'm planning on using four 1-ton come-alongs in each corner with 3/16 galvanized cable.
My fear is that the horizontal component of the wire strain will prove problematic, but I may be mistaken. Any specific building additions/precautions I need to include?
Any advice would be greatly appreciated.
Keep tension in cables. Be weary of eyebolts. Free body diagrams. Got it!
Earthsuntech-
Thank you for those diagrams-- very helpful to visualize. "Crushed like it was made in tooth picks in heavy winds"-- maybe I'll have to relocate during storms or maybe that's part of the thrill of being alive!
I'll be back at the land in a little over a week and can get a better idea of the tree orientation I'm working with so I can make a wire cradle work. Will start constructing shortly thereafter-- pics to follow!
Make your tree platform triangular and you won't spend time trying to get tension distributed evenly.
Cables attach at all 4 corners...looped around pipe nipple then back through. Trees allow for almost completely vertical forces. Swinging is dampened by horizontal cable running underneath the platform to two trees. Perfect!
 http://files.engineering.com/getfile.aspx?folder=0b55020c-2ea5-423f-8cdf-4a76f0d94541&file=image.jpg
