Structural glass spider connection calculations
Sparkco
CA
i am currently designing a glass enclosure (box) with spider connectors and swivel fittings. Any idea or suggestion on the engineering calculations? Is there a software for this? Thanks!
What is this enclosure box for?
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
The box is for art protection. Exterior application. About 6 ft. in height. Service area is about 5 ft. x 5 ft.
So this is a weather enclosure to protect art?
Is it completely enclosed or open on one or more sides?
Mike McCann
MMC Engineering
Motto: KISS
Completely enclosed with the bottom open. My concerns are the following:
- Need to calculate the deflection of the glass.
- Need to calculation the stress point of the glass (swivel hole).
- Need to calculate the spider connectors.
Is there a procedure of doing this engineering calculation on this structural glazing with spider connection?
Thanks for your help.
Any reason you cannot use something like the CR Laurence glass connectors? You might want to consider setting out the specs for the enclosure and let the supplier provide you whatever calcs/info you require.
Brad
When I design glass, I use a FEA program with the actual support conditions to get a stress. Then I compare that to an allowable out of ASTM E-1300 - which is dependent on the type of glass.
Are you using annealed, heat strengthened, or tempered?
Composition of the glazing is as followed:
12mm tempered heat soaked tested, 0.060 PVB Sentry glass plus, 12mm tempered.
Is there anybody know how? Any suggestion?
